Hello.
Newbie asks that how I do an arch roof to a room? Like cave ceiling? We have some 3m width room and according to test (as a normal wall) arch extent is 118 degrees. In other words the arc is bent some 80 cm. Rgs, TM007
An arch roof
This topic has been viewed 2527 times and has 4 replies
Re: An arch roof
- Draw a wall of the length needed (3 mtr)
- Use Modify walls - Arc extent and set it to 118 degrees
- Apply texture(s) on inside and/or outside (rotate 90 degrees if needed)
- Export selection
- Import and rotate 90 degrees
- Export selection
Re: An arch roof
Hello hansmex. Thanks about guiding. I followed maybe wrong Your instructions because I couldn't "flip" the arch to top of the room. I try harder. Anyway nice to know that it is easy to make own library elements! Nice feature.
Re: An arch roof
This is missing in Mod walls : "(rotate 90 degrees if needed)
Re: An arch roof
Read the user guide on how to export part of a model, and in how to import and rotate it.
