unable to convert plan to .svg using sweerhome3d 6.5.2 on centos 7
This topic has been viewed 2554 times and has 2 replies
Shaggy1
Post by Shaggy1 »
Hi
System Info
$ cat /etc/centos-release
CentOS Linux release 7.6.1810 (Core)
$ uname -a
Linux lb-cam-bca-12 3.10.0-1062.1.1.el7.x86_64 #1 SMP Fri Sep 13 22:55:44 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
$ java -version
openjdk version "1.8.0_292"
OpenJDK Runtime Environment (build 1.8.0_292-b10)
OpenJDK 64-Bit Server VM (build 25.292-b10, mixed mode)
$ javaws -version
icedtea-web 1.7.1 (rhel-1.el7-x86_64)
I downloaded SweetHome3D.jnlp and used the command:
$ javaws SweetHome3D.jnlp
to open it.
This seemed to work OK, but when I open a .sh3d file and try to convert it to svg format by going to:
Plan->Export to SVG format ...
It does not do anything. "Export to SVG format ..." does not highlight.
If I install the same sweet home version on a windows 10 machine I can export to .svg fine.
Would anyone have any idea why this might not work on a centos 7 machine ?
Is this the correct way to run swwet home on linux (using the .jnlp file), or do I need to download a different file ?
Shaggy1
Re: unable to convert plan to .svg using sweerhome3d 6.5.2 on centos 7
Post by Shaggy1 »
Ok. Initially I was running as root which it seems did enough to open the app, but when I tried running as a normal user it was unable to start - various exceptions thrown by java, so I guess javaws is not the way to go. (Not really sure what javaws is, but it looked like it was trying to run using a web browser).
I've installed snap and will try to install sweethome using that.
Why not trying the official version available at SourceForge.net?
It contains two scripts to launch Sweet Home 3D: [font=courier new]SweetHome3D[/font] and [font=courier new]SweetHome3D-Java3D-1_5_2[/font] which should work if the first one doesn't.
