Can someone help me with this please? I have seen FAQS but adding -Xmx in ini file but seems no effect on v6.5. I am on Windows10 Pro 64bit 20H2 latest.
Help needed to change java max heap size
This topic has been viewed 5946 times and has 4 replies
reddy.shyam
- Member
reddy.shyam
- Member
Re: Help needed to change java max heap size
Sorry, the post was incomplete. I have 16GB of RAM but even changing requirement to -Xmx6g doesnot have any effect. It still uses only 2GB of ram though I have more than 50% free of 16GB
Are you sure your file is named [font=courier new]SweetHome3D.l4j.ini[/font] and not [font=courier new]SweetHome3D.l4j.ini.txt[/font]?
reddy.shyam
- Member
Hi Emmanuel,
Thanks for looking into it. yes, its definitely .ini file.
reddy.shyam
- Member
Hi Emmanuel,
Just checked, changed from 6GB to 4GB and now it is using 3GB instead of 2. Is it OS dependent?
