Angled Windows
This topic has been viewed 5609 times and has 7 replies
stelvio.rosset
Country: Finland
Angled Windows
Post by stelvio.rosset »
Hello all, any suggestion how to create angled window?
Example:
Thanks for help.
SeppoV12
Country: Finland
Re: Angled Windows
Post by SeppoV12 »
I made couple angled windows with Sketchup Make 2017 (still free, I think). Those windows available if wanted.
No idea how to create such with SH3D.
Seppo
SeppoV12
Country: Finland
Re: Angled Windows
Post by SeppoV12 »
.. hope I understood correctly your sketch.. [:)]
stelvio.rosset
Country: Finland
Re: Angled Windows
Hi Seppo, yes you got exactly the idea. Do you think I can import your model, if possible, into sh3d?
SeppoV12
Country: Finland
Re: Angled Windows
Post by SeppoV12 »
Smaller window and bigger window.
Both are in .DAE -format so you can use Import Furniture to get them into SH3D.
Inside and outside surfaces are different material so you can use different 'paint' for inside and outside parts.
SeppoV12
Country: Finland
Re: Angled Windows
Post by SeppoV12 »
Rendering these windows might show unwanted colors/materials 'cladding_stucco_white' and 'material' bleeding through.
In this case use Modify furniture - Materials and make those materials invisible.
I have not found other solution to remove them.. sorry
crackwood01
Country: Canada
Re: Angled Windows
Post by crackwood01 »
using the shape generator plugin you can create your own window shape, set his opacity, then, export it as an obj file
Shape Generator 1.2
Then you could add some boxes around it as the window frame.
Export all the selection as an obj file
Import the new obj file as a door on window
and VOILÀ
SeppoV12
Country: Finland
Re: Angled Windows
Post by SeppoV12 »
Excellent solution, crackwood01 [=D>]
- uses only SH3D-tools AND
- avoid all problems I mentioned when creating window with SketchUp
This is the way I will make my windows!
