Shop Equipment and Tools
This topic has been viewed 8326 times and has 4 replies
I've searched this forum and all the libraries I can find for shop equipment with no luck. Table saws, drill presses, tool cabinets, peg board, bench grinders and similar. Any guidance appreciated.
Re: Shop Equipment and Tools
On the 3D models page, the Trimble Sketchup Warehouse is listed.
Obviously you didn't look there....
table saw
drill press
tool cabinet
peg board
bench grinder
table saw
drill press
tool cabinet
peg board
bench grinder
Is there a way to convert the SKP file formats to a compatible format (obj, dae, kmz, or 3ds) to use with Sweet Home 3d?
rustypheonix
- Country: USA
I have found that I do not need to convert when I download from the Trimble warehouse. There is an option at the bottom of the pull down menu in that site when you download the item to down load in Collada format. Sweethome can import those files just fine. Now if you find a SKP file somewhere else, there are online converters that I found, but not tried, that can convert to OBJ format.
Yes, as explained in this page [;)]
