App crash when loading big files in Ubuntu 20.10
This topic has been viewed 4796 times and has 0 replies
Nothor
Country: Spanien
Post by Nothor »
Hi you all,
I use Sweet home 3D since years ago, always in Ubuntu, but in the last version 20.10 and with Sweet home 6.4.2 (with Java3D 1.5.2) I have noticed a problem loading "big" files, or more than big, with a lot of different objects.
Sweet home 3D crashes and resets the whole Gnome Desktop.
After investigating a lot I realized, this doesn't happen if I open Sweethome as Root (with sudo). [:-/]
At the end the problem was with the amount of RAM memory available for java in Ubuntu.
In order to check the amount of RAM reserved execute
java -XshowSettings:vm
The ouput will start with something like this:
	VM settings:
		Max. Heap Size (Estimated): 1.67G
		Ergonomics Machine Class: server
		Using VM: OpenJDK 64-Bit Server VM
Where the "Heap Size" is the memory.
In my system I have 8GB of RAM so I have increased to 4GB in order to be sure it will not crash at start.
In order to do that, simply add this env variable "_JAVA_OPTIONS" with the amount of RAM available, before execute Sweethome
_JAVA_OPTIONS=-Xmx4096m ./SweetHome3D-Java3D-1_5_2
And that's it.
I hope it helps other like me [:)]
