This might be a bug
This topic has been viewed 5680 times and has 2 replies
La_Maudite
Country: Canada
This might be a bug
Post by La_Maudite »
Hello everyone,
This is my first post here. Let me first thank all the developers and maintainers for Sweet Home 3D. I'm especially glad it runs under Linux. Great stuff! [:)]
So here is my problem, which might be a bug or it might be that I'm not using the program properly with sloping walls. You tell me.
Like I said, I have a room with sloping walls. When I create the room, everthing looks fine in 2D. Also, I checked that the area is also computed correctly.
When I look at it in 3D, there's a polygon (triangle) following the top of the one wall and connectig to a point at the top of another sloping wall. For me it's a single triangle. This polygone doesn't get textured like the floor of the room. Also, it appears in 3D only from certain points of view.
Here's a screenshot and the sh3d file that I'm working on.
sh3d file
Thanks in advance
Carl
Re: This might be a bug
Modify rooms - and disable the ceiling.
SH3D has difficulties calculating roofs/ceilings for rooms with sloping walls. The triangle you see is an incoorect ceiling.
La_Maudite
Country: Canada
Thank you!
