Hi all,
I'm trying out the online version, but I can't work out how to change the units from imperial to metric. Can you assist?
Thanks!
Online version - change units to metric?
This topic has been viewed 10417 times and has 10 replies
Re: Online version - change units to metric?
This is not possible in the current version of the Online version, unless you know how to fool your navigator to let it think you're not in a country which uses imperial system.
well, for example, i have the same problem - imperial units instead of metric and i'm in "metric" location...
Same here - in metric country, stuck with inches.
Same here, and I can't install the programme locally as I'm getting registry errors
It would be great to be able to change the units to metric in the online version.
What registry errors do you get? Maybe you could try to install Java and run the JAR Executable version.
Please repair the on-line version to work with the metric system!
Be patient, the development of the new Online version is far from being finished.
CharlesScalliet
- Country: South Africa
Is there still no way of working in Metric ?
ferclaverino
- Country: Argentina
Hi, you can change your language on chrome by settings: https://stackoverflow.com/questions/372 ... me-browser
or using an extension: https://chrome.google.com/webstore/deta ... hdlmmlafcc
