I upgraded SweetHome to version 2.0 and now there is no 3D view of my previously created projects. What's wrong? Am I missing something?
No 3D view in 2.0
This topic has been viewed 5301 times and has 4 replies
Re: No 3D view in 2.0
Miserably, you seem not to be alone.
As proposed by aperezm in https://sourceforge.net/tracker/?func=detail&aid=2802547&group_id=152568&atid=784665 try to run Sweet Home 3D from its Jar file by following these instructions:
1. Install Java at http://java.com if you didn't already
2. Download http://prdownloads.sourceforge.net/sweethome3d/SweetHome3D-2.0.jar
3. Open a run dialog from Windows Start menu > Run...
4. Type the following command in one line:
javaw -Xmx512m -Dsun.java2d.opengl=false -Dsun.java2d.d3d=true -Dsun.java2d.noddraw=false -Dsun.java2d.ddoffscreen=true -Dsun.java2d.ddscale=true -Dj3d.rend=d3d -jar \path\to\SweetHome3D-2.0.jar
(replace "\path\to" by the real path where the file "SweetHome3D-2.0.jar" can be found)
5. Click on Ok
Please report here or in bug tracker if it works or not.
5. Click on Ok
Witold_Krakowski
this is a workaround... will it be fixed properly????? does anyone from the dev care about this issue???
Here's a similar and easier one. Click on the following link :
http://www.sweethome3d.eu/SweetHome3D-DirectX.jnlp
I'd loved too but it's not easy for me to find a bug that doesn't happen on my system (and fortunately on almost all systems).
I (until now, the programing team counts one person) care about all bugs, but I can't master bugs that happen in drivers and libraries used by Sweet Home 3D.
One last thing : I recall you that Sweet Home 3D is free and released under GNU GPL license available http://www.gnu.org/copyleft/gpl.txt . The section 15. of this licence clearly states that it this program is provided "as is" without warranty of any kind. So please keep cool!
cristiano.orlando
Fixed it
deleted (from the lib sub-folder, inside Sweet Home 3d folder) j3dcore-ogl.dll
j3dcore-ogl-cg.dll
j3dcore-ogl-chk.dll
That worked like a charm on my computer, now the program runs 3d with no problem
j3dcore-ogl-cg.dll
j3dcore-ogl-chk.dll
