Wände verbinden
This topic has been viewed 8452 times and has 3 replies
Doublebass
Country: Deutschland
Wände verbinden
Post by Doublebass »
Hi all,
when you make a room by walls, they often do not really "connect" properly.
(They do if you make the room by building all they walls at once, clicking only one time after each part is done. But sometimes, this is not an option.)
How it is:
https://ibb.co/qRB1Kty
How it should be:
https://ibb.co/Y0xNzgx
I made the 2nd pic by manually stretching the upper wall, making it long enough to start exactly at the position of the other wall.
But this cannot be the appropriate solution? It can easily be messed up by unprecise drawing.
There must be a way to "close" the wall automatically??
Re: Wände verbinden
You should have double-clicked at the end of the last wall, or afterwards, you may select the walls to join and choose the menu item Plan > Join walls.
Doublebass
Re: Wände verbinden
or afterwards,
That didn't work, repeatedly.
Then I repeated trying it even more, then it worked... [:-?]
Thanks!
Country: UK
Re: Wände verbinden
Post by Mike53 »
