The Furniture Library Editor crashed (actually hung up) while I was importing a model from a zip archive. The library that I had created up to that point had not been saved.
Now, I have found the location of the saved furniture and their previews in the work folder of SH3D. My question is, is it possible to recover the unsaved the library from this folder's contents?
Rebuild unsaved Furniture Library with FLE?
This topic has been viewed 7465 times and has 2 replies
Re: Rebuild unsaved Furniture Library with FLE?
As you probably observed, this folder contains files with temporary names. You could relaunch the editor then drag and drop all the .zip files you found in that folder onto the editor window.
Thank you! Worked perfectly!
