confused I need help with a complex roof
This topic has been viewed 7570 times and has 11 replies
Shralen
Country: Canada/Québec
Post by Shralen »
I started working on the house roof yesterday. At first, I made the magenta wall on the first floor and dived it so I could make a triangle. But then I wondered: Would I still be able to customize my room?
So today I started over, I made the first floor slop and then added the white triangle on an extra level.
In case the image broke: https://sta.sh/01hgzyswmkzs
Not pretty right?... So I tested something, I made the triangle but starting from the first floor, to see if I could customize it.
In case the image broke: https://sta.sh/041fbjvgkxe
As I thought the pink carry over the other wall and ceiling... I just want the carpeted room to be pink not the rest. So as you see I have no idea how to make my triangular wall.
I need help with this.
If you need more explanation on this house you can go on my other topic: http://www.sweethome3d.com/support/foru ... read,10436
If you have any question feel free to ask.
I'm more comfortable writing in English, but I can also write in French.
 ,___,
(OvO)   Hoot
 /)_)
Shralen
Re: I need help with a complex roof
Post by Shralen »
So I'm still trying to figure out how to make my inclined walls. But here an update:
Front:
In case the image broke:https://sta.sh/0u1hfcz1qdt
Back:
In case the image broke: https://sta.sh/01tjvnb1di49
I'm not 100% happy with this, but it looks better. I'm having a hard time figuring how to my inclined walls look nice...
 ,___,
(OvO)   Hoot
 /)_)
Shralen
Post by Shralen »
So... Yeah I'm still trying to understand how to make my slope. So I made some 'fake' roof to see if it would work and all.
In case the image broke: https://sta.sh/029q3b6ismvz
It still doesn't fit... so I guess I have to make the Cyan higher?
Or edit the part of the first flor that pops out?
 ,___,
(OvO)   Hoot
 /)_)
Post by VeroniQ »
Example 15 of the Sweet Home 3D Gallery has got a complex roof a little bit like that. Did you have a look at its file?
Shralen
Post by Shralen »
Thanx for the tip, I'll study that house file.
 ,___,
(OvO)   Hoot
 /)_)
Country: UK
Post by Mike53 »
Hi Shralen
HERE is a zip file that contains 2 projects and some screen shots, hopefully you can use them to help you understand how the roof panels can be made with the shape generator tool and also the way to use rooms to help create your wall colouring's. You will see that some of the walls are joined and some are not.
Good luck
Shralen
Post by Shralen »
Thank Mike.
I tried the generator tool, it would be perfect if I wanted my roof the same format as my room, but I want it to exceed said room. Such as:
In case the image broke: https://sta.sh/0cs3lkt0pip
I used the square for this example.
Also is there a way to get notified when someone answers our tread/us?
 ,___,
(OvO)   Hoot
 /)_)
Shralen
Post by Shralen »
Once more I tried things with a 'fake' roof, by using the square and triangle.
Front:
In case the image broke: https://sta.sh/0dnlmiza1ox
Back:
In case the image broke: https://sta.sh/01tpmtrtgpc5
It is far from perfect, but it gives you an idea of what I'm trying to do. I did try the shape generator tool, but since I want my shape to exceed the house it is not that easy. I'm not that good in math so it is getting quite complex to make the roof...
 ,___,
(OvO)   Hoot
 /)_)
Gildaniel
Country: Russia
Post by Gildaniel »
Hi!
You can make complex roof with walls and this feature http://www.sweethome3d.com/support/foru ... hread,3242
Draw wall on base level, ajust start and end height, add windows if needed
Copy as a new furniture and paste, then you can adjust angle
Shralen
Post by Shralen »
I actually managed to make 3 roofs with the shape generator tool.
In case the image broke: https://sta.sh/03jwc9ub91c
I send Mike53 the .sh3d file, they said they would try to help me. We'll see if we can figure out how to do the rest.
 ,___,
(OvO)   Hoot
 /)_)
