Greetings,
Is there a tutorial for Shape Generator? I have attempted building a trapezoidal box with no success, example:
https://drive.google.com/file/d/1olFl8o ... sp=sharing
I have been calculating via the plug in like this, X 5 .199 X6 .000 1 X .199 2 X.000 and so on ..
Or would there be a better solution for drawing the speaker box?
Please note the actual speaker components shown I will import as a front image.
Thanks in advance
Regards
Kostas
Shape Generator
This topic has been viewed 4658 times and has 2 replies
Re: Shape Generator
If sharp corners are not a problem, shape generator is easiest way to create trapezoidal box.
I feel that tutorial is not necessay: draw 3D-sketch of your shape on paper with all corners visible, then mark points in same manner as generator does. I hope that next picture help.
Handy feature is that generator remember your earlier coordinates, so it's easy to make fixes.
Good luck!
Seppo
Good luck!
Seppo
Re: Shape Generator
Thank you Seppo for taking the time much appreciated.
Regards
Kostas
Regards
Kostas
Users browsing this forum: samratahmedzayan
