How to set elevation on lines?
This topic has been viewed 3481 times and has 4 replies
baldhead
Country: België
Post by baldhead »
Hello all,
Any ideas on how to set the elevation on lines - as I would like to use the "polylines" in order to draw the electric wires/ UTP / water pipes ... but I can't 'elevate' them as I can with furniture and other object. Am I missing something?
Thanks in advance!
Re: How to set elevation on lines?
Post by VeroniQ »
I suggest to add an other level and display it at the heigh of your choice... You'll even be able to display or not this level. If you don't know well how to handle levels, have a look at some tips of the blog.
baldhead
Country: België
Post by baldhead »
Well, that's exactly my problem, how can I change the height (elevation)?
If I want to edit the line - this is the popup I get:
https://ibb.co/WDggVJS
JefJago
Post by JefJago »
I have the same question. Probably it is not possible it would be convenient however
Have you looked at the Wirings Plugin? That plugin is specifically created to add wirings like electrical lines.
http://www.sweethome3d.com/support/foru ... read,11503
