Reordering Levels
This topic has been viewed 10624 times and has 9 replies
Reordering Levels
Is it possible to reorder the levels once they are created?
Re: Reordering Levels
Yes......
Double click on the tab of the level you wish to change, a box will open enabling you to modify height, depth of floor and elevation, unfortunately, whilst the box shows all elevations you can only change settings for the one you initially choose. good luck
Thanks. I looked into that, but the ability to reorder them seems to not be selectable. Any ideas?
- UbuntuBirdy
- Country: Switzerland
- Contact:
You have to set the height of the levels to reorder them.
Pascal
Okay, I think I've got it even if the order arrows do not work. What you do is change the elevation to -8'. That drops it below ground level, for instance.
Wow, that was a cross-post. You are quite correct.
double click or right click on 1 of the tabs here .....
from the window that opens
you can modify the individual level and see where it moves to in relation to the other levels.
You can then open a window to the other levels
Yep. Thanks, that helps.
Now if I can just view the basement area of a building in a view like you show of that house.
Can you show a view of what you are seeing?
Thanks anyway, Pal. I got it figured out. It's starting to look halfway decent.
