Floor is raised in photo above real floor height
This topic has been viewed 4126 times and has 3 replies
Texchanchan
Country: Fort Worth, Texas, United States
Post by Texchanchan »
In the next-to-best photo rendering the floors are all about 2 feet higher than in the original. This gives the impression the room has been partially filled with concrete.
Here is an example of what I mean. Note the stripe down the middle where you can see the depth and texture of the real floor. That stripe is above a wall in the basement - another confusing factor.
Here is what it's really like in there:
Country: UK
Re: Floor is raised in photo above real floor height
Post by Mike53 »
it looks like your ceilings in your basement are showing, check the "height" setting in your basement level
Texchanchan
That worked. It also fixed the ceiling height. Thank you.
Texchanchan
oops, wrong photo. Here's a good one.
