I have a problem at lauch under Linux/64bits. When I execute the script, I have the following error:
./SweetHome3D: /home/trasher/Téléchargement/SweetHome3D-1.8/jre1.6.0_12/bin/java: /lib/ld-linux.so.2: bad ELF interpreter: Aucun fichier ou dossier de ce type
./SweetHome3D: line 11: /home/trasher/Téléchargement/SweetHome3D-1.8/jre1.6.0_12/bin/java: Succès
If I replace in the script « "$PROGRAM_DIR"/jre1.6.0_12/bin/java » by « /opt/jdk1.6.0_13/bin/java » (Java 64bits version) and « $PROGRAM_DIR"/jre1.6.0_12/lib/javaws.jar » by « /opt/jdk1.6.0_13/jre/lib/javaws.jar », I have the following:
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: Could not initialize class javax.media.j3d.VirtualUniverse
at javax.media.j3d.GraphicsConfigTemplate3D.getBestConfiguration(GraphicsConfigTemplate3D.java:321)
at java.awt.GraphicsDevice.getBestConfiguration(GraphicsDevice.java:159)
at com.eteks.sweethome3d.j3d.Component3DManager.getCanvas3D(Unknown Source)
at com.eteks.sweethome3d.j3d.Component3DManager.getOnscreenCanvas3D(Unknown Source)
at com.eteks.sweethome3d.swing.HomeComponent3D.<init>(Unknown Source)
at com.eteks.sweethome3d.swing.SwingViewFactory.createView3D(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController3D.getView(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.createPlanView3DPane(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.createMainPane(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.<init>(Unknown Source)
at com.eteks.sweethome3d.swing.SwingViewFactory.createHomeView(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController.getView(Unknown Source)
at com.eteks.sweethome3d.HomeFramePane.<init>(Unknown Source)
at com.eteks.sweethome3d.HomeFrameController.getView(Unknown Source)
at com.eteks.sweethome3d.HomeFrameController.displayView(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D$5.collectionChanged(Unknown Source)
at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionChanged(Unknown Source)
at com.eteks.sweethome3d.model.HomeApplication.addHome(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.runApplication(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.access$100(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D$1.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Any idea what's the problem ?
Regards
This topic has been viewed 14283 times and has 2 replies
Johan_Cwiklinski
Re: /lib/ld-linux.so.2: bad ELF interpreter
I have come here for the same reason. I run Sweet Home 3D on a 64 bit linux box but I had to download some 32 bit libraries. Also the package itself (tgz) comes with 32 bit JRE packed in. All in all, it is running as a 32 bit application.
Is there any way how to run it on 64 bit JRE? Or is there any reason why Sheet Home 3D runs on / is shipped with 32 bit JRE?
I tried to run it under my 64 bit JDK I have installed but without success.
Thank you in advance.
Keep your great work up. It is really amazing application. Thanks for all your work!
You can run Sweet Home 3D on a 64 bit JRE with Java Web Start and the JNLP file http://www.sweethome3d.eu/SweetHome3D.64bits.jnlp
Note : this JNLP file will be available until the next version of Sweet Home 3D that will be released in the coming days. Then the default JNLP file of Sweet Home 3D will incorporate changes for 64 bits.
