Hi all.
I am beginner in Java. I found this project this week, and i am interested in it.
I wanna ask that whether there is any IRC Channel for this project. So that we can communicate with each other easily.
cheers
Jarod
IRC Channel
This topic has been viewed 5544 times and has 6 replies
Re: IRC Channel
Please, let's use this forum or email for the first steps of your discussion.
What do you want to know?
Jarod_Yang
Re: IRC Channel
I have downloaded the source file
In the "README" you only provided the compile way by Eclipse
I got to try to compile by "ant" in command terminal. but i failed.
Could you please provide me a way to compile the source code in terminal
cheers
Jarod
cheers
Jarod
Jarod_Yang
Re: IRC Channel
ps.
my system is ubuntu linux
cheers
cheers
Re: IRC Channel
If you installed ant and java 5 or 6 correctly, the build.xml should work without any problem (all the files delivered in Sweet Home 3D project are built with Ant).
What error do you get?
Jarod_Yang
Re: IRC Channel
u4457331@n115lt23:~/Desktop/SweetHome3D$ ant build
Buildfile: build.xml
build:
[mkdir] Created dir: /home/u4457331/Desktop/SweetHome3D/build/classes
[javac] Compiling 2 source files to /home/u4457331/Desktop/SweetHome3D/build/classes
[javac] Compiling 151 source files to /home/u4457331/Desktop/SweetHome3D/build/classes
[javac] Note: Some input files use or override a deprecated API.
[javac] Note: Recompile with -Xlint:deprecation for details.
[javac] Note: Some input files use unchecked or unsafe operations.
[javac] Note: Recompile with -Xlint:unchecked for details.
[copy] Copying 175 files to /home/u4457331/Desktop/SweetHome3D/build/classes
[copy] Copied 15 empty directories to 1 empty directory under /home/u4457331/Desktop/SweetHome3D/build/classes
[zip] Building zip: /home/u4457331/Desktop/SweetHome3D/build/SweetHome3D.jar
[delete] Deleting directory /home/u4457331/Desktop/SweetHome3D/build/classes
BUILD SUCCESSFUL
It is OK until now. when i try to run the jar file there is the mistake
u4457331@n115lt23:~/Desktop/SweetHome3D$ cd build
u4457331@n115lt23:~/Desktop/SweetHome3D/build$ java -jar SweetHome3D.jar
Invalid or corrupt jarfile SweetHome3D.jar
I dont konw how to deal with it
Is there any step wrong?
my ant is the latest version
cheers
Jarod
build:
BUILD SUCCESSFUL
cheers
Jarod
Re: IRC Channel
You should have read *all* the comments at the beginning of the build.xml file http://sweethome3d.cvs.sourceforge.net/viewvc/sweethome3d/SweetHome3D/build.xml?revision=1.75&view=markup
It describes the different available targets and I think the one you're looking for is the target named "jarExecutable", isn't it?
