Using SH3D Portable's Java Files to Run the TLE & FLE
This topic has been viewed 6198 times and has 7 replies
T3NZ3N
Country: 天下
Post by T3NZ3N »
In the documentation, I think it's mentioned that we can just run the TLE & FLE JARs from the Portable SH3D's own Java Files in it's own jre Directory.
I can't figure out how to set this up so I can run the TLE or FLE jar files from the files in the jre folder.
I'm running win10pro
The only executables with the java program Icon I found in the jre/windows/x64/jre8/bin were the javaw.exe
I tried simply dragging & dropping the jar to that and every other exe file in the bin, but nothing happened.
I currently have jportable in the Portable SH3D directory along with the Portable Launcher, but I'd like to try and see if there is a way to launch them directly without those, by using only the files in jre/windows/x64/jre8/bin
Additionally, I'm curious if the Portable SH3D Executable is just a Natively packaged Java File.
Thanks for any help
Re: Using SH3D Portable's Java Files to Run the TLE & FLE
The command to run a JAR file is:
path/to/java.exe -jar executable.jar
(you may also use [font=courier new]javaw.exe[/font])
T3NZ3N
Country: 天下
Post by T3NZ3N »
How can I add that to the launch parameters of the jar?
and will it be dynamic, if the drive letter changes?
T3NZ3N
Country: 天下
Post by T3NZ3N »
And when you say "I may use javaw.exe", what does that mean? How do I use it to make it do something.
I'm not sure you can change the launch parameters if java is not installed.
If you want to reuse the command you should rather store it in a .BAT file.
Simply replace [font=courier new]java.exe[/font] by [font=courier new]javaw.exe[/font] in the command I wrote.
T3NZ3N
Country: 天下
Post by T3NZ3N »
would the batch file just look like this?
"E:/Portable Programs/3D Programs/SweetHome3D-6.3-portable/jre/windows/x64/jre8/bin/java.exe" -jar "E:/Portable Programs/3D Programs/SweetHome3D-6.3-portable/FurnitureLibraryEditor-1.25.jar"
that didn't work for me
T3NZ3N
Country: 天下
Post by T3NZ3N »
Except I used javaw.exe, as there is no java.exe in that folder
T3NZ3N
Country: 天下
Post by T3NZ3N »
Sorry, you need an edit button. The entire Bat file looked like this:
Run "E:/Portable Programs/3D Programs/SweetHome3D-6.3-portable/jre/windows/x64/jre8/bin/javaw.exe" -jar "E:/Portable Programs/3D Programs/SweetHome3D-6.3-portable/FurnitureLibraryEditor-1.25.jar"
