I have built a basement level (by creating a new level and making it a negative elevation) I have the dimensions, floor, walls and access slope (a ramp) all completed. How can I show the ground level render and have my ground level texture cover the underground structure I created? When I view at my 0 elevation level the below ground room has an open top and I can see inside.
If I create a floor at ground level (covering this space) I cannot have the ground level image flow seamlessly over the new floor area.
Trying to build an underground structure
This topic has been viewed 6664 times and has 1 replies
[email protected]
Re: Trying to build an underground structure
Either you select the upper level, or you select the 3D View > Display all levels menu item.
