I'm looking for Geodesic Dome
Did someone made a model like wall or other ?
Thanks for all.
Geodesic Dome
This topic has been viewed 6196 times and has 2 replies
Re: Geodesic Dome
I think that it is impossible to create (in SH3D) geodesic dome that has wall properties. That is because walls in SH3D are always vertical.
And this means that you can not build geodesic dome (for example) with triangular wall pieces.
Otherwise walls can be even ring-shaped (two arcs 180 degrees each or 90 +270 degrees (270=max. value for arc) and so on..)
If you don't need to add doors and windows, you can download domes from 3D Warehouse (https://3dwarehouse.sketchup.com/search/?q=dome).
You can also create ring-shaped wall and add that dome on top of it if that exact shape is not absolute requirement.
Hope that I have understood your meaning right..
Seppo
Seppo
- bdfd
Re: Geodesic Dome
Hi,Hi,
Thanks for all.
Few months ago, I realized this :
PS : I have some cupola/dome in my store, just ask me in PM [;)]
