Sweet Home 3D 4.2
This topic has been viewed 442696 times and has 98 replies
Re: Sweet Home 3D 4.2
Emmanuel,
I always use the installed version, that´s the 881 byte file.
The installers versions still use Java 6 (information shown in About dialog), but it would be astonishing that it could provoke a bad interaction with Java 7 installed in the system. I'll check...
Emmanuel,
The webstart version opens every file I try without problems.
Haans
m@
Post by m@ »
Thanks for the new version!
Although the checkbox "check for updates" was enabled in my 4.1.-Version, the software did not inform me about the new release. Even hitting the "check now" button did not help. Maybe this was a bug in 4.1. ?
hal9000
Country: Spain
Post by hal9000 »
m@, if you re-read a few posts above you'll see that version 4.2 is currently on beta stage.
hal900, version 4.2 is out since yesterday evening (I posted a message in this thread, updated the main page, the History page and published an article in the blog today).
m@, the updates check feature displays a message coming from the web server. As there's always a risk to miss a last big issue, I prefer not to rush to inform every users when I release a new version, and updated this update message only tonight (thanks for recalling me anyway). It should work now. [:)]
hal9000
Country: Spain
Post by hal9000 »
Oops. So it was me who missed the important post. [:">] And when I say "the post" I mean just the post, because I read the later post by Hansmex about the problem with the files from previous versions, but the last post I read about a release was beta 16.
Well, good to know it's out, anyway. [:)]
m@... I said nothing. [:-"]
[:p]
Hans,
About the crash you reported in version 4.2, could you check whether it happens with the installer version 4.1? I suspect you didn't encounter this bug before the release of version 4.2, because you were running the Beta with Java 7 and not with Java 6 as does the installer version.
m@
Post by m@ »
Hi Emmanuel
I encounter a strange problem with the .dmg-version 4.2.: the render process stops after a few minutes and the "save" Button turns from inactive to active. It is even possible to save the uncompleted photo. But no error message appears. What could be wrong?
m@
Do you think it's a regression? Could you reproduce this issue more than once? If yes, could you [url=mailto:[email protected]]send me[/url] the faulty file?
