"C:\Program files\SweetHome3D\jre8\bin\javaw.exe" -jar [i]path\to[/i]\FurnitureLibraryEditor-1.19.jarCode: Select all
"C:\Program files\SweetHome3D\jre8\bin\javaw.exe" -jar [i]path\to[/i]\FurnitureLibraryEditor-1.19.jarI'm running xubuntu 16.04, with Java 8. I can't get the downloaded file to run by double clicking or with the command line, so I installed it through the software manager, and it's running great. However, I have searched everywhere and can't find the Furniture.jre file to delete.I should deliver the default catalog as a SH3F file too. [:)]
At the moment, you can quite easily get rid of the default furniture catalog of Sweet Home 3D, by following these steps:
- Ensure you installed Sweet Home 3D from its installer (not with Java Web Start).
- Remove the file named Furniture.jar from Sweet Home 3D installed files. Under Windows and Linux, this file can be found in the lib subdirectory of Sweet Home 3D installation directory
#!/bin/sh
# Retrieve Sweet Home 3D directory
PROGRAM=`readlink "$0"`
if [ "$PROGRAM" = "" ];then PROGRAM=$0
fi PROGRAM_DIR=`dirname "$PROGRAM"`
# Run Sweet Home 3D exec
exec "$PROGRAM_DIR"/jre8/bin/java -Xmx1024m -classpath "$PROGRAM_DIR"/lib/FurnitureLibraryEditor-1.20.jar:"$PROGRAM_DIR"/lib/Furniture.jar:"$PROGRAM_DIR"/lib/Textures.jar:"$PROGRAM_DIR"/lib/Help.jar:"$PROGRAM_DIR"/lib/iText-2.1.7.jar:"$PROGRAM_DIR"/lib/freehep-vectorgraphics-svg-2.1.1b.jar:"$PROGRAM_DIR"/lib/sunflow-0.07.3i.jar:"$PROGRAM_DIR"/lib/jmf.jar:"$PROGRAM_DIR"/lib/batik-svgpathparser-1.7.jar:"$PROGRAM_DIR"/lib/j3dcore.jar:"$PROGRAM_DIR"/lib/j3dutils.jar:"$PROGRAM_DIR"/lib/vecmath.jar:"$PROGRAM_DIR"/jre8/lib/javaws.jar -Djava.library.path="$PROGRAM_DIR"/lib com.eteks.furniturelibraryeditor.FurnitureLibraryEditor -open "$1"Code: Select all
com.eteks.sweethome3d.model.RecorderException: Invalid furniture library file
at com.eteks.furniturelibraryeditor.io.FurnitureLibraryFileRecorder.readFurnitureLibrary(Unknown Source)
at com.eteks.furniturelibraryeditor.viewcontroller.EditorController$3.call(Unknown Source)
at java.util.concurrent.FutureTask.run(FutureTask.java:266) at com.eteks.sweethome3d.viewcontroller.ThreadedTaskController$1.run(Unknown Source)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: Can't copy file to /tmp/furniture3331676379223917287.sh3f
at com.eteks.furniturelibraryeditor.io.FurnitureLibraryFileRecorder.copyFile(Unknown Source) ... 11 moreUsers browsing this forum: Google [Bot], MSN [Bot]
