Other rendering quality levels
This topic has been viewed 131016 times and has 41 replies
Re: Other rendering quality levels (Advanced settings of photo rendering plug-in)
I think this is a great idea for a plugin. If you could make the possibilities for rendering movies at 60 FPS I would be very greatful.
Thanks - i was able to view the PhotoRenderer properties file and that answered the questions well enough. I was able to come up with better renders thanks to the explanations.
I will also take a look at the PDF you pointed to...
At the risk of a major "thread necro", I've got to say: what an awesome plugin! Just found it and installed it this evening and had a bit of a play - primarily to get access to the global illumination options - and I'm absolutely rapt!
Many thanks enkonyito.
Crazy Kiwi bloke
Debian "buster" 10 64bit
Sweet Home 3D 6.3 64bit
i5 Quad-core 3.1GHz
8GB 1333MHz DDR3 RAM
i5 Quad-core 3.1GHz
Re: Advanced settings of photo rendering plug-in
Thanks for adding YafaRay settings [:)]
So just to clarify... I have SH3D 7 (with Yafaray built in) and AdvancedSettingsPhotoRendering 1.4 plugin.
Should we uninstall YafarayRendering plugin completely? Or does it still have some function?
I don’t see a good reason to keep YafaRayRendering plug-in installed if you run Sweet Home 3D v7.
It offers less features than YafaRay renderer version in Sweet Home 3D.
Version 1.4.1
- removal of properties identical to the default ones
EnkoNyito
CinemaWalls
I have already used these settings, but that's the problem, that even the value "normalLens.radius = 1" already gives such a blur as if there is a lens with a 1.8 "hole" on the camera - the DOF is very small.
At the value of radius = 3, the grip is generally several centimeters, almost everything is out of focus. About the other values, more than 3 - I don't understand at all - why are they?
I would like to suggest making several radius values up to one, instead of those useless ones. This would greatly improve the capabilities and quality of the renderers.
I'm applying the renderers for an example
https://imgur.com/a/wJ2WAyb
https://imgur.com/a/17UqX0A
Try a value smaller than 1 (0.5, 0.2 etc)
