SurroundRoom Plugin
This topic has been viewed 12664 times and has 22 replies
Ollie_Jess
Country: México
Re: SurroundRoom Plugin
Post by Ollie_Jess »
Xlance wrote: Wed Nov 25, 2026 7:52 pm AWESOME WORK :-)
Just note that Random should affect X or Y or Z axis independently or any combination e.g. X and Z
Thank you very much, Xlance! I'm really glad you like it.
You're right. The pieces look fine in the plan and in 3D: the plugin rotates them around X and then around Y. That allows angle combinations the Modify furniture dialog can't produce.
I thought about leaving it that way to allow those new combinations. However, when you open the Modify furniture dialog, neither axis is selected, and choosing one resets the other tilt to 0. So, to avoid confusing users, I will fix it: in the next update the random X and Y tilts will be exclusive. You'll choose X or Y, and you can still combine it with the Z orientation, the same as in Sweet Home 3D.
Thanks again for testing it and for the feedback!
Xlance
Post by Xlance »
I meant random scaling ;-)
Ollie_Jess
Country: México
Xlance wrote: Thu Nov 26, 2026 8:04 pm I meant random scaling ;-)
Do you mean adding small X, Y, Z offsets? Z is already handled through elevation. I left out X and Y offsets because they could cause overlaps with other objects or between them, and might clash with other options (Actually, I almost didn't add random depth for the same reason, but I ended up keeping it). Now that I think about it, it'd actually be useful in some cases.
