Thank you very much, Xlance! I'm really glad you like it.Xlance wrote: Wed Nov 25, 2026 7:52 pm AWESOME WORK
Just note that Random should affect X or Y or Z axis independently or any combination e.g. X and Z
You're right. The pieces look fine in the plan and in 3D: the plugin rotates them around X and then around Y. That allows angle combinations the Modify furniture dialog can't produce.
I thought about leaving it that way to allow those new combinations. However, when you open the Modify furniture dialog, neither axis is selected, and choosing one resets the other tilt to 0. So, to avoid confusing users, I will fix it: in the next update the random X and Y tilts will be exclusive. You'll choose X or Y, and you can still combine it with the Z orientation, the same as in Sweet Home 3D.
Thanks again for testing it and for the feedback!
