cool Replacer Plugin 1.1
This topic has been viewed 48923 times and has 10 replies
Ollie_Jess
Country: México
Re: Replacer Plugin 1.1
Post by Ollie_Jess »
Hello to all!
Replacer 2 is ready. An improved window, replacement from the catalog, groups of replacements, per-material colors and textures, random values and much more.
HOW TO USE IT
Step 1.- Select in the plan or the furniture list the objects you want to replace, and open "Tools" > "Replace furniture...".
Step 2.- The selection goes to the "Objects to replace" panel. To change it, select other objects and click that panel.
Step 3.- Select the new object in the plan or the catalog and click the "Replacement" panel. To use several replacements, hold Shift/Ctrl while clicking the panel, or use its "+" button: they form a replacement group.
Step 4.- Check the properties to copy from the original objects (by default position, elevation, angle and level).
Step 5.- Choose the scope: "Selected only" or "All matching". With "All matching", tick "View matches" to see in the plan which objects will be replaced.
Step 6.- Click "Replace". The replacement can be undone with Edit > Undo.
WHAT'S NEW IN VERSION 2
Window and selection
  • Two panels, "Objects to replace" and "Replacement". Click a panel to assign the selected objects, remove items one by one, or swap both panels with one button.
  • The replacement can come from the plan or the catalog.
  • Replacement groups: several objects, and one is picked at random for each replaced item (double weight = double probability).
Properties to copy
  • Now also X/Y rotation, shininess, light power and movable, besides position, elevation, level, angle, size, mirror, color and texture.
  • Colors and textures per material: choose which materials of the original give their look to which materials of the replacement, or use the whole object.
  • Scale unchecked dimensions proportionally (following one dimension or the average).
  • Alignment: an anchor point (9 positions, top view) when the sizes differ. Doors and windows in walls stay fitted to their opening.
Random values
  • Any property can take a random value: absolute, added, or a percentage of the original, keeping proportions if you want.
  • Random mirror with a probability.
  • Random color/texture from a weighted list, or by varying red, green and blue, for the whole object or per material. "Reroll" draws again.
Matching ("All matching")
  • Match by 3D model and/or name, with a shininess tolerance and texture matched by name or by image.
  • Groups: require an identical internal layout, or match each 3D model inside the selected groups.
  • "View matches" highlights in the plan every object that will be replaced.
Groups
  • Replace groups as a whole, or the elements inside them down to the subgroup depth you choose (counted from the outer group or from the innermost one).
Other
  • Option to skip hidden or locked furniture.
  • Interface in 19 languages.
REQUIREMENTS AND INSTALLATION Thanks to everyone who reported bugs and ideas. I hope you like it, and feedback is always welcome!
Replacer-2.sh3p
(264.53 KiB) Downloaded 15 times
