my 2story building (so far)
This topic has been viewed 17925 times and has 9 replies
macfrog
Country: Germany
Post by macfrog »
Hello everybody,
i just want to share my actual results "abusing" sh3d as a tool for creating rather architectual than interior designs, even if its not meant to [:)]
the upper level is imported as an obj and placed roughly to the right spot.
also the roof is a bit clumsy.
i had to remove all the furniture due to my memory issues still tickling my powerbook [:((]
first, outside view from south
scnd, view from the upper gallery downwards, the sunlight coming in still appears to dark in my opinion, maybe radiosity support would solve this...
greets
macfrog
TSUKASA
Country: TUNISIE
Re: my 2story building (so far)
Post by TSUKASA »
Great job!
sampathmalaka
Country: Peradeniya, Sri Lanka
Post by sampathmalaka »
[;)] Nice one! Keep it up [:)]
macfrog
Country: Germany
Post by macfrog »
sampathmalaka, tsukasa,
thanx for your replies! sure i will continue to work on this project, it's far from finished or even perfect.
Greetz
macfrog
macfrog,
Looking again at your nice house, I see an opportunity to improve your roofs. Currently you are using the standard roof model available in red and blue: a very inefficient model because it's covered in some kind of tiles. They add a lot of detail, but aren't visible. And when you add a texture to your roof, rendering them is a nightmare.
Maybe you'd want to have a look at my latest tutorial on sloping ceilings and roofs. Chapter 3 (page 8) describes an alternative method to make roofs, that may be very well suited for your design. The resulting model is much lighter than your current roof parts, and can be easily customised with different textures on both sides,
Good luck,
macfrog
Country: Germany
Post by macfrog »
Hans,
i used your very helpful tips to create the required parts of the roof again (now for v4 of the design).
here's a shot from "construction site" a.k.a the project holding all parts on stock:
and here is small render of the now weatherproof upper level:
the solar panels are separate objects, of course [:D]
thanx for your advice(s)!
macfrog
macfrog,
Nice to see that it works so well !
Have you thought about exporting some windows and then importing them again, while rotating them 90 degrees, so that they correctly fit in the assembled roof?
macfrog
Country: Germany
Post by macfrog »
Hans,
yes, the rotating issue while using that method applies to the windows as well as to the textures (which i had to learn twice).
but in this case the window's correct alignment is not very important, as long i get proper light through the roof and nice morning shadows into that building [:D]
macfrog
pencilart
Post by pencilart »
macfrog: I really loved your house rendering. I especially loved the interior stair way. One of these days I want to try that too.
Hans: Very nice tutorial. I will have to try it out sometime soon!
Bobski60
Post by Bobski60 »
Hans, you are the main man, great tutorial, shall try making that this eve (or however long it takes me lol.
