Loss of info after Export to OBJ
This topic has been viewed 5638 times and has 4 replies
Emmanuel,
The function Export as OBJ format suffers from loss of info.
I exported a bunch of mirrors, then re-imported them, but they weren't mirrors anymore. I've reported a similar problem earlier with changes in glass transparency, if I remember correctly.
I tried this in v3.0-b9 and v2.6.
Re: Loss of info after Export to OBJ
But glass transparency bug should have been fixed meanwhile, haven't it?
Yes, when I export/import glass it stays transparent.
The fix for this bug will be available in the next beta version.
Meanwhile you should know that it works with the plug-in Copy as new furniture.
I'll check it out once beta 10 arrives.
Thank you!
