I created an online version - sweet3D
This topic has been viewed 406 times and has 2 replies
Paul6552
Country: Österreich
Post by Paul6552 »
I’ve created an online version of Sweet Home 3D — called sweet3D.
Yes, there is already an online version, but it’s poor. Since I’ve used Sweet Home 3D for several of my own projects but found certain things frustrating—for instance, the inability to display the 2D and 3D views on separate monitors—Claude simply went ahead and programmed a solution! :-D
So, if anyone has any Sweet Home 3D projects, you can easily import them here. Everything is free to use, no installation needed. Everything is running in the browser.
github: https://github.com/Paul6552/sweet3D
App: https://sweet3d.vercel.app
matthewhussey30
Re: I created an online version - sweet3D
Post by matthewhussey30 »
:ugeek: Looks great. thanks for sharing! The separate 2D/3D monitor feature is really useful. Does it support exporting projects back to the original Sweet Home 3D format?
Paul6552
Country: Österreich
Post by Paul6552 »
Yes, it should work. I’ve tested it with two projects. However, if you use features that are exclusive to Sweet3D (such as generating roofs or terrain), those features will naturally only work within Sweet3D. If you import the project into Sweet Home 3D, it will work there as well—just without those specific extensions.
