Many years ago i made a model of the house I was building and I applied a certain texture to the outside walls.
I have a new project now where I wanted to use the same texture. However, I cannot find this texture back in the library!
I can copy a wall from the old design and paste it in my new project and the wall will show up correctly.
Now I have a box that I would like apply the same texture to, but it does not show up in the library.
I have no idea where I got this particular texture...
Is there a way to extract the texture from the wall?
Thanks.
Retrieve texture from wall
This topic has been viewed 3916 times and has 3 replies
Re: Retrieve texture from wall
Export the wall. The export will have an .obj and .mtl file AND an image file with your texture [:)]
Import that image as a new texture so you can use it for other furniture. Make sure to give it a recognizable name during import (if necessary).
Thanks, but how exactly do I export a wall?
OK, I found it!
Thanks!
Thanks!
