Objects lose transparency when grouping
This topic has been viewed 7525 times and has 16 replies
Re: Objects lose transparency when grouping
Emmanuel:
It also happens in v2.5. The Aerial View is correct, only when using Virtual Visitor does the problem occur.
db4tech
Country: UK
Post by db4tech »
Thank you Emmanuel,
I've not had chance to try this yet, this bug fix will be a great help, for my multi level gallery model! I am currently having to use carefully placed boxes, to fill the gaps in-between upper and lower doors, placed inside the invisible wall furniture model. [:)]
Hi Hans,
Would trying the built in 'Create photo' on the Fast setting, help test to see if the missing door reappears, or if it is a driver problem?
I've not looked at the code for built in Create photo yet, so I don't know if it is created using a basic shader, or retrieving an OpenGL 3D render direct the from the GPU (for anyone reading this who might not know. GPU = Graphics Processing Unit)
If the Fast render is a retrieved GPU render, then trying the Best setting should help prove whether or not it is a driver issue.
By the way, which version of Ubuntu are you using, 10.4.1? I mght download and try it (will be in a virtual machine though) and see how it goes. You will be able to help me then, as I'm not that used to Linux. [:)]
Hope you're both well and having a nice weekend!
db4tech
Emmanuel, db5tech,
QUOTE
The other problem has something to do with refreshing the screen. When I drag an inserted door out of the wall, the door disappears and only the glass window in the door remains visible. When I do a right-click and (without selecting anything) a left-click, the screen refreshes correctly.
ENDQUOTE
Maybe it's a driver problem, I wouldn't know. Just seems that the refreshing isn't as fast or automatic as it should be. The right-click left-click solves the issue.
As for Ubuntu: I'm using Lucid 10.04. It recognizes that Windows is already installed and proposes to do a dual install, so that you can choose at start-up. Of course you can also install it on a virtual machine.
db4tech
Country: UK
Post by db4tech »
Thanks Han5, [:D]
I think I prefer to try it from within a virtual machine first, as don't really want the GRUB (boot loader code) adding to my boot sector.
Since posting my previous message I downloaded 10.4.1 Desktop, I guess it shouldn't be that different?
Will set it installing! [:)]
db[font=century gothic]'-¦[/font]tech
Edit:
Ah, Lucid is the name of version 10.4.1. D'oh! [:))] At first I thought you were using a different flavour of Ubuntu [:">]
db4tech
Country: UK
Post by db4tech »
Hi Emmanuel,
Just download the install version of 2.6 and tried your MultiLevelWindows.sh3d file, it works perfectly! [:)]
Hans,
I tried adding a door with glass, then moving it in and out of the wall, the door still appears correctly.
Thank you from one very happy user!! [:)]
db4tech
Here's an image of a multi levels house test I did with version 2.6 [:)]
pencilart
Post by pencilart »
Nice render Emmanuel! :D :D [\:D/] [:)>-]
