The Staircase Generator is a plug-in designed for Sweet Home 3D that allows users to create highly customizable 3D staircases. The tool features a comprehensive parameters menu for fine-tuning dimensions, structural elements, handrails, and midrails. It also includes an integrated 2D Shape Designer for creating custom handrail profiles.
Real-World Application: Whether you are an interior designer pitching a sleek, modern glass-railing loft, or an architect ensuring a multi-story traditional home meets building codes, this plug-in provides the exact geometrical control you need.
https://sourceforge.net/p/sweethome3d/plug-ins/60/
Advanced Staircase generator plug-in v4.0
This topic has been viewed 30439 times and has 7 replies
Windows 64bit | Intel i7 | SH3D 8.0 + Plugins
Re: Advanced Staircase generator plug-in v4.0
I tested it, it works, and it's a very laborious plugin. Congratulations!
Some of the new features don't work (yet), but I think you'll get them to work (Y-shaped or T-shaped stairs).
The profile editor is very interesting (at least for me).
May I use it as inspiration for my other plugins?
In return, I could try to organize your source code better. 7625 lines in a single sheet is a bit too much and difficult to manage.
Translated with DeepL.com (free version)
@dorin
The translation is much, much better now! No 'funny' language constructions from a bad translator [:)]
@Keet
BTW My son has told me the same [#-o]
Is the same translator used in the past. The 'funny' constructions is 'my signature', it is part of mine.No 'funny' language constructions from a bad translator
Gents, feel free to update/upgrade/improve the plugin as you see fit [:)]
The Y shaped T shaped Inverted T Y shaped are a bit beyond my expertise so give it a try.
And yes you can use the shape designer code or upgrade it
Round landings or Polygonal landings also need to be added
Hi! I tried to organize the source files a little better.
Here is the plugin and here is the Eclipse folder.
Thanks for accepting!
@dorin
NICE WORK
Now try
Adding Round landings, Elliptical landings and Polygonal landings
Adding Y shaped, T shaped, Inverted Y shaped, Inverted T shaped
Cheers
NICE WORK
Now try
Cheers
