"Print to PDF" doesn't work on my portable version?
This topic has been viewed 3027 times and has 2 replies
Dirki
Post by Dirki »
When I click in the menu "File" Print to PDF" there are created none working 0 bytes PDF files.
What can I do to create working PDF files?
When I click on an icon like "Create walls" a message appears: "Create walls tip". Activating the check box let it pop up again after the next program start. How can I avoid this?
Actual (none Beta) stable, portable Sweet Home 3D
Windows 7 Premium Home Edition & Vista
Re: "Print to PDF" doesn't work on my portable version?
Until now, portable versions are built by other people and you probably picked up a buggy one unable to record preferences. Please try an other distribution.
By the way, once you found a portable version that works, it would be nice to report it here (you can report also the ones that failed).
Dirki
Post by Dirki »
Thank you Emmanuel,
I use this one, it is the only actual portable version I could find: http://www.sweethome3d.eu/support/forum ... DF9179268D
I assume, according the none working PDF function it is the same answer.
Thanks again, nice greetings, Dirk
Users browsing this forum: Amazon [Bot], Google [Bot], MSN [Bot], Semrush [Bot]
