who has SweetHome3D online source?
This topic has been viewed 14744 times and has 9 replies
bluesky5566
I think sweetHome3d run in my tomcat,and put in my web project,but,i don't know online save and read,please help me !
Re: who has SweetHome3D online source?
Save and read operation depends on how you want to organize user information your server. A default implementation is proposed in source code in PHP.
For more information please read also these subjects:
http://www.sweethome3d.com/support/foru ... hread,1454
http://www.sweethome3d.com/support/foru ... hread,1435
bluesky5566
thanks a lot,but I can't develop JSP likes PHP,please help me.this is my code.
<%@ page import="org.apache.commons.fileupload.*" pageEncoding="UTF-8"%>
<%@ page import="org.apache.commons.fileupload.servlet.*" %>
<%@ page import="com.scand.fileupload.*" %>
<%@ page import="java.io.*" %>
<%@ page import="java.util.*,java.sql.*" %>
String uploadFolder = request.getRealPath("/"+"\\upload");
// Check that we have a file upload request
boolean isMultipart = FileUpload.isMultipartContent(request);
if (!isMultipart) {
out.println ("Use multipart form to upload a file!");
} else {
String fileId = request.getSession().getId().toString();
//创建数据工厂
FileItemFactory factory = new ProgressMonitorFileItemFactory(request, fileId);
ServletFileUpload upload = new ServletFileUpload(factory);
//从请求对象中获得要上传对象
List /* FileItem */ items = upload.parseRequest(request);
String sql = "insert into house_photos (house_id,photo_name) values(?,?)";
//迭代所有上传的FileItem
Iterator iter = items.iterator();
while (iter.hasNext()) {
FileItem item = (FileItem) iter.next();
if (item.isFormField()) {
//如果是表单对象再此处处理
} else {
//处理上传文件
String fileName = item.getName();
int i2 = fileName.lastIndexOf("\\");
if(i2>-1) fileName = fileName.substring(i2+1);
File dirs = new File(uploadFolder);
if(!dirs.exists()){
dirs.mkdir();
//dirs.mkdirs();
long l = System.currentTimeMillis();
// String houzhui = fileName.substring(fileName.lastIndexOf("."));
fileName = fileName+l+".sh3d";
if(true){
File uploadedFile = new File(dirs,fileName);
item.write(uploadedFile);
session.setAttribute("FileUpload.Progress."+fileId,"-1");
out.write(1);
System.out.print("1");
out.clear();
}else{
session.setAttribute("FileUpload.Progress."+fileId,"-2");
,but it also prompt "can't save home in 'myhome'"!!1
if (!isMultipart) {
} else {
//创建数据工厂
//从请求对象中获得要上传对象
//迭代所有上传的FileItem
//如果是表单对象再此处处理
} else {
//处理上传文件
if(!dirs.exists()){
dirs.mkdir();
//dirs.mkdirs();
if(true){
out.write(1);
out.clear();
}else{
out.clear();Code: Select all
out.write(1);Please insert your code between [ code] [ /code] tags.
nicoloconte
Hi all, I'm trying to embed SH3D in my Drupal site but I have several problems with the saving and reading functionality. I downloaded listHomes.php and both readHOme.php and writeHome.php but I can't make them work. When I click on the "open" icon the input window show me the source of the listHomes.php file.Save and read operation depends on how you want to organize user information your server. A default implementation is proposed in source code in PHP.
Where am I doing wrong?
Thank you very much.
If I were you, I would learn basics about server scripts and PHP before even trying to deploy these PHP files...
nicoloconte
I know PHP and Java well, but I need some documentation. Can you help me?
More and more people ask for help about deploying an online version without even presenting themselves and/or explaining what they want it for.
So yes, I can help but if this deployment is for commercial purpose, don't expect it will be for free.
I guess you'll understand that voluntary work can have some limits...
PixelStudios
Hi Puybaret
I need to deploy an online version for commercial purpose. Please help us how to further?
Regards
Rajesh
Pixel Studios
Regards
Rajesh
Pixel Studios
What do you miss in the previous links?
