I'm searching for a way to render a 3D picture from my design without the indoor shadow from the sun.
Picture from the model room:
Link to picture (OneDrive)
In Detail: I need to have an open view into the rooms, but for the rendering the system have to think that the rooms have an ceiling.
I've tryed already to use following plug-in:
PhotoVideoRendering-2.8
can someone help my?
thank you so far.
kind regards
3d rendering without shadows from the sun (indoor)
This topic has been viewed 206366 times and has 3 replies
MarioSambol
- Country: Croatia
Re: 3d rendering without shadows from the sun (indoor)
Hi, Try this way. Create two invisible light panels. The first one is at the ceiling height larger than the entire spatial plan, say strength 4. The second one is the same size, just raised from the floor maybe 1 cm and rotated 180 degrees so that the light goes towards the ceiling, say strength 2. When rendering, set the time to midnight. In the floor settings, deactivate the ceiling not to be displayed. The result should be satisfactory.
- Daniels118
- Country: Italy
If you want to preserve sunlight coming from windows, you can use this method:
https://sweethome3d.com/support/forum/v ... 1807#55022
- captaincook
- Country: France
Peut être que cette autre solution peut vous aider aussi.
Un panneau lumineux invisible couvrant la surface de la maison situé à 500 cm au dessus et orienté pour éclairer vers le bas (angle X =270°) et intensité lumineuse réglée à 3%.
Ne pas oublier de désactiver les plafonds.
L'image finale est crée avec le visiteur virtuel placé à 1500 cm de haut et un angle de tête de 90°, de nuit et sans éclairage ni de plafonnier ni du ciel.
Et une deuxième image.
