staircase generator
This topic has been viewed 224195 times and has 16 replies
adibuyono
Country: Indonesia
staircase generator
Post by adibuyono »
First of all, thank you very much to provide such useful software for open source community.
I always having trouble with the staircase provided in furniture, and I have zero knowledge about 3D modelling.
I wish there is an easy way to create staircase met every user need.
I think staircase generator would be a great idea for all of us.
Staircase generator I mean is like :
1. first, we need to choose which kind of staircase we are going to regenerate. i.e : L shape staircase, U shape staircase, direct staircase.
2. Then, we need to enter how many steps for each part of stair case. For example : I choose L shape staircase, the lower part of the staircase is 4 steps, and the higher part of the staircase is 11 steps.
3. Last, we need to input how is the height and wide of each steps.
and voila, the software generate a staircase for us.
Anyway, this is just my two cents. If i am asking too much, I am really sorry.
And again, sorry for my bad English.
Hope everyone understand what I am trying to describe.
harbinger
Country: Clearwater, FL, US
Re: staircase generator
Post by harbinger »
+10 on this!
My staircases are never cookie-cutter, and they almost always require a special model, so of course i would support this.
Altho it would be very complicated, this kind of customization would help take SH3D out of the "tinkering" genre of software to something more serious.
This probably would be best suited as a plugin, but hopefully such a feature would allow for curved steps, customized bannisters/railing and its placement, and multiple texturization.
I disagree on HOW MANY steps would need to be input, but rather the rise of each step, and the altitude that needs to be covered. Perhaps a separate option would allow you to put in a "break" for turning the angle of the staircase.
dorin
Post by dorin »
I think this one and others could be a subject in developers part.
In my imagination I see an entry in Menu like "Tools" or "Generators" with few entries:
-shape generator
-stairs or staircase generator
-roof generator
-furniture builder
-terrain generator
All of this could be made as individual plugins.
First step was made by shape generator.
For stairs generator could be used as start point for plugin developers the code (free) from AOI named Array... in combination with shape generator.
Try the Staircase generator plug-in available here.
arpy
Country: US
Post by arpy »
I'd like to generate a U shaped staircase with landing but one where I can specify the number of steps on each side. For example, I want 15 total steps, 12 on one side, then the landing, then 3 more down from the landing.
Is there anyway to do this?
Xlance
Post by Xlance »
Hello All
I've created an updated interface with more proposed functions for the plugin, but no actual programming as I'm not proficient in java.
If anyone is interested to actually implement the functions, you'll find an eclipse project here along with explanations:
https://sourceforge.net/p/sweethome3d/f ... ests/1169/
Thank You
Windows 64bit | Intel i7 | SH3D 8.0 + Plugins
Xlance
Post by Xlance »
The next upgrade ! work in progress :-)
https://freeimage.host/i/Knhqodb
Width of the staircase
Total height of staircase
Height of each step
Depth of each step
Height of stringers
Thickness of stringers
Height of handrail from tread
Width/thickness of handrail
Width of a baluster
Height of baluster
Distance between balusters
Radius of spiral staircase
Total rotation angle (spiral)
Horizontal placement offset
Vertical placement offset
Depth placement offset
Select staircase shape
Open file chooser to load custom obj baluster
Open file chooser to load custom txt handrail profile
dorin
Post by dorin »
Looks very promising!
One remark: you have to rotate the left handrail profile to make it symmetrical with the right.
I like also the option to choose the turn between round and corner.
Xlance
Post by Xlance »
Could be done I guess :-)
Very tricky ! I could supply the source if you can implement it ;-)
[:)] Four Turn Stair Preview: https://freeimage.host/i/KToegK7
Xlance
Post by Xlance »
Palace Staircase: https://freeimage.host/i/KutmQAx
[full parametric modelling by the upgraded version of Staircase generator plugin and rendered on level 3]:
