Hi;
Is there a way to set a polyline default for a project?
I want to use the same size, shape, arrow design, color, etc. for a polyline without having to go back each time I draw one and choose all these options many times.
I have not been able to find a way to make this a default.
Thank you!
Set a default polyline for color, size arrow, shape, etc. ??
This topic has been viewed 25934 times and has 2 replies
Re: Set a default polyline for color, size arrow, shape, etc. ??
Unfortunately that is not possible.
A work-around is setting the properties for the first polyline and copy/paste it for the next. With copy/paste all changes on the original are copied too.
Hi.
I found a work around.
I used the default polyline to make many in each room.
Then, in each room, I clicked on one polyline and then pressed ctrl-A to highlight all of them, I picked the modify polyline option and when the polyline window popped up, I chose the styles/size/color I wanted then clicked ok and all polylines changed to the new choice.
Thank you for your time and giving me forum access.
