https://www.mediafire.com/file/q2xtxy3w ... n.jar/file
Enjoy
Camera Data Generator v1.1
This topic has been viewed 9575 times and has 17 replies
Camera Data Generator v1.1n Fixed
Windows 64bit | Intel i7 | SH3D 8.0 + Plugins
Re: Camera Data Generator v1.1n Fixed
Now it works OK.
The calendar AND the csv output.
Problem:
I steel receive some errors:
Like to find first what LaF are provided by the local OS.
Problem:
java.lang.ClassNotFoundException: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
Probably you could find a better solution.at AdvancedCameraDataGenerator.<init>(AdvancedCameraDataGenerator.java:148)
Camera Data Generator v1.1p
Hello
+ Added a multi stage Fallback Mechanism for selecting look and feel of the UI, the program will:
Check first if OS is Mac or not,
if yes > apply MacOS LookAndFeel
if not > will detect installed LookAndFeels > apply system default
if failed > apply Cross Platform LookAndFeel
if failed > apply Metal LookAndFeel
+ Added junit.jar which was missing
https://www.mediafire.com/file/mycx02vm ... p.jar/file
Cheers
Cheers
Re: Camera Data Generator v1.1p
Now it appear to works correctly. [=D>]
I think this could be the final 1.1.
One more suggestion (but not mandatory):
When click OK -> close (exit) the application.
You've made a very good job!
PS (also not mandatory)
You could put cityCoordinates and timeZoneOffsets in two text files and loaded from there.
In this way the main program will be more easy to read.
Export CAD to SH3D
@Dorin and Everyone
Take a look at this brand new plugin
https://sourceforge.net/p/sweethome3d/plug-ins/56/
It appears on the generation of an elliptical path that for the intermediate points there is an inaccuracy between the position of the point and the given Fov
Sorry replace in my previous message Fov by Yaw
Camera Data Generator v1.1Q
Hello [:)]
Added a new function / checkbox to switch CSV separator from ( , ) to ( ; ) for Euro OS
Note:
CameraBagPlugin-1.8 plugin now supports importing CSV files with ( ; ) separator
https://sourceforge.net/p/sweethome3d/p ... r-1.1Q.jar
Note:
