Pond
This topic has been viewed 5111 times and has 10 replies
skank
Pond
Post by skank »
Hi
I have created my garden
I created a second floor beneath it.
Made some walls of the pond
When i look back to my floor plan, i can see the walls going down. Which is great
What i want to do now, is to have it filled with water :p but keep the transparancy
How can i do that?
Cause when i add floor at +0, transparancy and walls are gone..
I cant leave it blank either, curious
MarioSambol
Country: Croatia
Re: Pond
Post by MarioSambol »
I think you should have an object with transparency on it and some kind of water surface texture.
skank
Re: Pond
Post by skank »
How do i give an object transparancy?
JonnyD
Re: Pond
Post by JonnyD »
Find a glass shelf and alter the materials so only the glass is visible. Change the glass texture to water and stretch it to fit your pond. You may need to use it in your negative layer
Re: Pond
The tips&tricks page seems to have disappeared. There was a sample project there that had step-by-step descriptions on how to create a pond/swimmingpool.
It's not that difficult. You already have the hole but you are missing the water.
Stretch a shallow box so it completely covers the opening of the hole. Make all sides except the top invisible and set the water texture from the texture list for the top. Export the object. Edit the mtl file and add a line "d 0.4" at the bottom of the "newmtl top" block.
Save and import. Put the object on the below ground level and elevate it to where you want the top of the water to be. Done.
Setting a value for d closer to 1.0 makes the water less transparent if that is what you need.
skank
Re: Pond
Post by skank »
@KEet its chinese for me, how do i do a shallow box
Willing to give me such an object? it can be a rectangle
Re: Pond
You can drag a box from the catalog and resize it. Just set it's height to 1 cm or so, doesn't really matter since the actual height will disappear anyway.
When you modify the box you can click the button "Materials" on the bottom left of the dialog. It then shows 6 sides for materials: top, bottom, left, right, front, and back. You can make them invisible in the same dialog suing the radio button "invisible". Only the top should remain: click the button "Texture" and from the texture list select a water texture (type 'water' in the little box at the bottom of the list). Click OK, OK and you can export the box.
Set the d value in the MTL file that results from the export. Import the OBJ file and you have your water.
skank
Re: Pond
Post by skank »
i can only export to svg or csv not obj
skank
Re: Pond
Post by skank »
got it
skank
Re: Pond
Post by skank »
this is the mtl now
# Generated by Sweet Home 3D - vr jan 24 19:40:11 CET 2025
# http://www.sweethome3d.com/
newmtl top
illum 2
Ka 0.2 0.2 0.2
Kd 1.0 1.0 1.0
Ks 0.46875 0.46875 0.46875
Ns 60.0
d 0.4
