i see no way to set a Dimension to an exact figure without dragging and tryiong to get it exact - which can take forever
how do you just set it to an exact length?
Missing Functions: How do i set a Dimension to an exact figure?
This topic has been viewed 3315 times and has 5 replies
Re: Missing Functions: How do i set a Dimension to an exact figure?
Press <enter> then type the length. Again it’s explained in the help!
as i thought i previously replied, that option simply does not appear to work after trying several times - you do NOT appear to be able to enter any figure; and ignores the fact that easy simple and logical fix is to simply have field settings on edit
It's available only at Dimension lines creation time, and when the plan has the focus (bordered by a blue line).
really? how helpful.
MarioSambol
- Country: Croatia
Double click on dimension and manually enter the number you need.
