I'm on a new system (SuSE 11.2) and have the latest Java 6.
When I started SH3D, it won't shut down.
Now what?
SH3D won't exit/quit
This topic has been viewed 3772 times and has 6 replies
Re: SH3D won't exit/quit
Pencilart:
Switch to Ubuntu 10.04?
Using and loving Ubuntu since 2008
Pencilart, could you launch Sweet Home 3D in a terminal and report here what happens when you choose File > Quit if ever a text appears in the terminal?
ok, here is what it says:
./SweetHome3D
Exception in thread "AWT-EventQueue-0" java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
at com.eteks.sweethome3d.swing.ControllerAction.actionPerformed(Unknown Source)
at com.eteks.sweethome3d.swing.ResourceAction$AbstractDecoratedAction.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
... 29 more
Caused by: java.lang.RuntimeException: java.util.prefs.BackingStoreException: Couldn't get file lock.
at com.eteks.sweethome3d.SweetHome3D$StandaloneSingleInstanceService.removeSingleInstanceListener(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D$2.collectionChanged(Unknown Source)
at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionChanged(Unknown Source)
at com.eteks.sweethome3d.model.HomeApplication.deleteHome(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController.exit(Unknown Source)
... 33 more
Caused by: java.util.prefs.BackingStoreException: Couldn't get file lock.
at java.util.prefs.FileSystemPreferences.sync(Unknown Source)
... 39 more
Jun 23, 2010 4:51:40 PM java.util.prefs.FileSystemPreferences syncWorld
WARNING: Couldn't flush user prefs: java.util.prefs.BackingStoreException: Couldn't get file lock.
./SweetHome3D
... 29 more
... 33 more
... 39 more
Quit failed because it couldn't write preferences.
Check if you have the rights to write in your home directory, and if you can write in its .java/.userPrefs/com/eteks/sweethome3d subdirectory too.
in the .java folder I found this crazy file name:
_!'%!cg"0!'8!~g"p!'w!b!"1!(:!a@"v!'4!.g"w!'8!b!"5!'0!~@"z!'g=
What on earth can that be?
I found eteks' prefs here like you said:
/home/<username>/.java/.userPrefs/com the permissions are set just like all the others drwxr-xr-x
Can I just delete all the occurances of .eteks and will it just start over?
I found the problem! I had made the mistake of telling it to open SweetHome3D with java. After reading in the OpenSuSE forums I found the directions for fixing that. Once I removed that association, I opened SH3D and after playing with it for a bit, I shut it down and it worked!
