confused Strong difference in texture color in plan view
This topic has been viewed 3157 times and has 1 replies
AlexKalopsia
Country: Sweden
Post by AlexKalopsia »
Hi there, I am having this issue where the texture I use is rendered quite differently in the plan view.
Is there a fix for this?
Re: Strong difference in texture color in plan view
No solution for that because it's inheritant to the different purposes (and thus the programmed handling) of the 2D and 3D views. The 2D is just a 'simple' display for designing your plan where the 3D view displays a 3D representation, i.e. different angles that cause color differences. The real difference comes when you are rendering photo's. That will add light, shadows, reflections, etc. You add light sources to get the end result you are aiming for.
When you start rendering photo's check this thread from GaudiGalopin3324 who is a master with adding light sources to get great photo renderings. You will also find many tips&tricks in that (long!) thread.
P.S. That are pretty dangerous shelves you got in the room [:)]
