rose Apartment project with lighting by invisible hemispheres. I continue advertising
This topic has been viewed 258220 times and has 291 replies
Re: Apartment project with lighting by invisible hemispheres. I continue advertising
You did it! Yes, the reflection of the cat should have been the back of the head. But what matters most is that the process works.
You just have to remember that if you have a reflection, that you need the backside of the same image as well.
GaudiGalopin3324
Country: Russia
Post by GaudiGalopin3324 »
To get images in the mirror, another mask layer was needed. Gif files with a mirror-scaled waterfall and a mirror-scaled cat were placed under it.
The second mask is needed to leave the reflection in the mirror visible, there is a big hole for this.
The excellent work of GaudiGalopin3324 about adding animated gifs in a Sweet Home 3D video is now available in a single pdf manual: AddGifsInVideo
GaudiGalopin3324
Country: Russia
Excellent qualified work, Keet! I hope these experiments will be useful! Thank you for your patience!! We will continue.
Post by VeroniQ »
Thank you very much to both of you. The manual is very clear.
GaudiGalopin3324
Country: Russia
Thank you very much VeroniQ, but without the help of dear Keet, this would not have been possible. Thanks to him too!
GaudiGalopin3324
Country: Russia
Please believe me. It's very simple. You just need to master removing the background from the video. There are a huge number of these gif files and video files. The first frame is a SH3D render. The second frame is a freeze frame from the final clip. There's only one layer-a mask to sit the girl down at the table and put the rabbit on the floor.
https://www.mediafire.com/file/eoxty0mx ... 2.avi/file
GaudiGalopin3324
Country: Russia
You can watch a movie on the TV screen!! You can even do it all, from beginning to end. A real movie in the render. I like it)). The photo editor has the ability to deform the video card in the future. And it will be like on a real screen, from the angle, from the side. [:D]
https://www.mediafire.com/file/bt5l7mqh ... 6.avi/file
GaudiGalopin3324
Country: Russia
the view from the window. This is a very promising topic. For a live image, you need to search for a Timelapse video on YouTube. It is necessary that the camera be on a tripod, not moving. There may be landscapes with trees, city views, water with yachts. I took this video of the city, superimposed a flock of birds flying over it. But first I made a mask with holes from the SH3D render. I cleaned everything inside the windows, inside the TV and inside the fireplace.
For the convenience of cleaning the background, I made a render with bright green inserts in these places, then in Photoshop you can work with a magic wand, everything is cleaned in a few clicks. But I still made a big mistake, I didn't remove the glass in the windows. Interior reflections make cleaning much more difficult. It is better to completely remove the glass in the windows. To place a video of a landscape, it is very important to determine the horizon line. It is located at any view from the window exactly at the eye level of the viewer, I showed this line in red. Buildings in the city (the lowest boundary of buildings and the sky in the picture) will always be slightly above this line, the sea is exactly along the line, the field is also like that. This time I put a cartoon on the TV for 10 minutes in full. The free version of VideoPad has done it! more than 500MB, and that's okay. I made the deformation of the video for TV through the VSDC video editor, it's more difficult with perspective, but you can still change the angle a little. But this editor can work with large amounts of video.
The final cartoon in the room
