confused High priority how to set grid steps ?
This topic has been viewed 4799 times and has 2 replies
zazay
Country: Maroc
Post by zazay »
when i want to creat the walls folowwing the real mezures i have the end of the shape does not stick with the start (i can not change the angle°) , if i can change the grid steps and make it smaller this can fix my problem.
any help please [:((]
Re: how to set grid steps ?
There’s no snap to grid feature and the grid step depends on the zoom factor.
If you want to enter precise measures, type <Enter> key while drawing walls to type its length. See also included help for more details.
zazay
Country: Maroc
Post by zazay »
Thank you for your replay i appreciate that.
I found the solution to my problem. I was right in thinking that perhaps the source of my issue was the angle changing by 15° when I tried to draw the wall , and I believe this is called magnetism.
The solution for anyone facing the same problem as me: Press and hold the “Alt” key while drawing walls or any other object where you need to change the angle. Then, you can adjust it by any number of degrees instead of being restricted to 15° increments. [;)]
