Hello!
i¨m new here and trying to create my own cabin. I'm looking for a fixed window with beveled edges as shown in picure.
1100mmX1400mm bevel 30 degrees.
Does anyone know where i can get (buy) this 3D model that i can use in Sweet Home 3D?
Thanks!
https://www.turbosquid.com/FullPreview/593027
Beveled edge window 30 degrees
This topic has been viewed 3996 times and has 2 replies
Re: Beveled edge window 30 degrees
Here's a version derived from the fixed window model available in the default catalog.
You'll just have to set its size and don't forget to select the Door or window option when you import it.
- Attachments
- trapezoidalFixedWindow.obj
- (2.27 KiB) Downloaded 612814 times
Thank you so much, Puybaret! [:)]
