I apologize for the very basic question.
I created a door but I want to see it open, so that I can see thru it.
How can I do?
Regards
marius
Opening a door
This topic has been viewed 12425 times and has 5 replies
Re: Opening a door
perhaps this topic will help you in Features use and tips Door swing in plan
Re: Opening a door
a simple solution is using a Door frame and set the door at a angle
Re: Opening a door
[Moderated] My Google search for "sweet home 3d open door" turns up this thread, which has over 5000 views, so I assume people want to know how to open a door in Sweet Home 3D, like I did. This is not explained anywhere for new users.
The answer, for anyone wondering, is to double-click on the door, or right-click and select "Modify furniture". In the pop-up, click the "Modify openings" button. From there you can see a 3D model of the door which you can click and drag to swing the door open or closed. Click OK to close the popups once you are done.
Re: Opening a door
maladroit, the solution you propose will work only for the doors in the existing libraries.
For door models designed by yourself, it's more complicate.
A.D.STUDIO
- Country: Australia
Re: Opening a door
Don't apologise, I learnt something here
