Hi, installed the new version 7.3 today on my Mac Mini M2 Pro, but it crashes instantly. Previous versions worked well.
Crash report says, that some "Code 1 Library" is missing...
Translated Report (Full Report Below)
Process: SweetHome3D [1230]
Path: /Applications/Sweet Home 3D.app/Contents/MacOS/SweetHome3D
Identifier: com.eteks.sweethome3d.SweetHome3D
Version: 7.3 (7300)
Code Type: X86-64 (Translated)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2024-04-08 12:44:42.2440 +0200
OS Version: macOS 14.4.1 (23E224)
Report Version: 12
Anonymous UUID: C2EE1AD6-4813-E6A0-DF7E-C476B04B0D7F
Time Awake Since Boot: 770 seconds
System Integrity Protection: enabled
Notes:
PC register does not match crashing frame (0x0 vs 0x10001CA78)
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Termination Reason: Namespace DYLD, Code 1 Library missing
Library not loaded: /System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher
Referenced from: <DB4461F7-56F8-5BE2-25DE-0B22B179E73D> /Applications/Sweet Home 3D.app/Contents/MacOS/SweetHome3D
Reason: tried: '/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher' (no such file), '/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher' (no such file, not in dyld cache), '/Library/Frameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher' (no such file), '/System/Library/Frameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher' (no such file, not in dyld cache)
(terminated at launch; ignore backtrace)
Error Formulating Crash Report:
Sweet Home 3D 7.3
This topic has been viewed 77824 times and has 23 replies
Re: Sweet Home 3D 7.3
Did it work with version 7.2 too?Previous versions worked well.
Found the reason. Sorry, it was my fault: I installed the wrong MAC version (SweetHome3D-7.3-macosx-10.4-10.9.dmg) instead of appropriate (SweetHome3D-7.3-macosx.dmg) for my MacOS 14.4.1 machine by simply clicking the green SourceForge download button.
By the way: Are there any plans to provide a native Apple Silicon arm64 build?
It's already the case. The application in SweetHome3D-7.3-macosx.dmg is for Intel and Apple Silicon.Are there any plans to provide a native Apple Silicon arm64 build?
