I think I'm narrowing in the problem.
The URL are not really a problem, I set the external URLs for the JavaScript interaction in the index.jsp and I set internal URLs for the call to the backend classes (ServerUserPreferences and HomeRecorder) the problem is the session. You store the reference to the file being opened in a session variable.
I see that behind the proxy, the sessionid is renewed at every call and the session variable is destroyed, so the WriteHomeEdits script assumes that the Home file was never opened in the first place. I will explore the possibility to create a custom session manager......
SweetHome3DJS - Porting plugin - ARM architecture support
This topic has been viewed 18539 times and has 27 replies
Re: SweetHome3DJS - Porting plugin - ARM architecture support
You may use [font=courier new]application[/font] instead of [font=courier new]session[/font] in [font=courier new]readHome.jsp[/font], [font=courier new]writeHomeEdits.jsp[/font] and [font=courier new]closeHome.jsp[/font]. It's used to store the reference copy of the edited file, so there's no risk that some conflicts happen here.
But if there's more than a user in your application, you'll have to manage session somewhere in case you don't want a user to edit the files of other users.
Hello Emmanuel, thanks it is a good idea, of course it would be more elegant to have a custom session, but this would take a serious amount of effort. Nevertheless by putting application instead of session, I'm back to my previous issue. There is something in this code that brings up to javascripts the URLs:
This is where there is a mix of server bound calls and client bounds calls that are using the newly crafted URLs. If I use server URLs (http://localhost....) the server classes are working fine but they somehow pass on the URL to Javascript, in the console I see this error message:
which is normal because the client do not "see" localhost.
If I use the regular URLs (http://PROXY_IP/PROXY_CONTEXT, the server classes will fail because they do not "see" the proxy.
So the classes that you have created to support SH3DJS are breaking proxy compatibility.
Sorry for the long post and thanks again for dedicating some time to my idea.....
serverUserPreferences = new ServerUserPreferences(
new URL [] {new URL(localBaseUrl, "lib/resources/DefaultFurnitureCatalog.json")}, localBaseUrl,
new URL [] {new URL(localBaseUrl, "lib/resources/DefaultTexturesCatalog.json")}, localBaseUrl);
getServletContext().setAttribute("serverUserPreferences", serverUserPreferences);This is where there is a mix of server bound calls and client bounds calls that are using the newly crafted URLs. If I use server URLs (http://localhost....) the server classes are working fine but they somehow pass on the URL to Javascript, in the console I see this error message:
Failed to load resource: net::ERR_CONNECTION_REFUSED
In your case, you should set [font=courier new]serverUserPreferences[/font] to [font=courier new]null[/font].
User preferences on server side are useful to reduce the size of the saved SH3D file, by replacing the furniture and textures stored in a SH3D file by URLs if they exist in the preferences catalogs too. This is the case in [font=courier new]HomeTest.sh3d[/font] where you'll see that the size is smaller after the first call to [font=courier new]writeHomeEdits.jsp[/font], because it contains some furniture of the default catalogs (but also some furniture and textures not found in it). But keeping a larger SH3D file on the server is not an issue, it will be just more data to send to the client when reading the home it contains. Anyway, if the designed home is built from scratch on the server which is probably what you want to propose, the [font=courier new]Home.xml[/font] entry in its SH3D file will contain only URLs and will be as small as possible.
Ok, yes the purpose is to get rid of the Fat Java client for the card users in Home Assistant; I do not see as a big problem to have bigger SH3D files (even though the load will be slower as no furniture library can be cached in the browser).
On the other hand I need to enlarge the default Furniture Catalog otherwise users will always need to do the first Home build in the Fat Java Client.
I did not get your comment on Home.xml but I am still learning on the architecture of SH3D.....
A SH3D file is actually a ZIP file containing texture images, furniture 3D models and icons, as well as an entry named [font=courier new]Home.xml[/font] which describes the designed home respecting this DTD. If you look at an example of [font=courier new]Home.xml[/font], you'll see that the [font=courier new]model[/font], [font=courier new]icon[/font] and [font=courier new]image[/font] attributes are equal to a number matching another entry in the SH3D file or a URL matching data on the server.
You'll find here instructions about how to add more furniture and textures libraries to the catalogs using the tool PropertiesToJson. Note that you can obtain also a JSON version of an existing SH3F or SH3T library file with the version 2.0 of the Furniture Library Editor and Textures Library Editor if you save it as a file ending by [font=courier new].json[/font]. This is easier than using PropertiesToJson but you'll probably have to change [font=courier new]furnitureResourcesURLBase[/font] and [font=courier new]texturesResourcesURLBase[/font] in application configuration (or adapt the relative URLs of [font=courier new]icon#[/font], [font=courier new]model#[/font] and [font=courier new]image#[/font] properties in generated JSON files).
Hello Emmanuel, I do not know if it is related, but according to your description, probably yes. By putting the ServerUserPreference to null, it works (even behind the proxy), but, the performances to load a complex model (10-20Mb) are seriously degraded. In fact your idea to have the furniture managed with independent files is very efficient and takes advantage of the browser cache. I wonder if you can think of a way (in your next releases) to have the serverUserPreferences to work well behing a proxy, by separating the backend URLs and the frontend-URLs. Maybe it is already the case as the Server class accepts 2 couples of URLs, but I could not figure it out
Hello Emmanuel, not sure if there was an acknowledgment from your side of an issue with making your ServerUserPreferences library work behind a proxy. My last assessment was that, when working behind a proxy, if you pass to ServerUserPreferences constructor:
- absolute URLs: the ServerUserPreferences code fails because it cannot reach the library
- relative URLs: the code fails because it expects absolute URLs
- local absolute URLs: ServerUserPreferences works, but the Javascript in the client cannot reach the resources
[/list=a]
In my opinion it should be up to the JavaScript library to calculate the URL based on relative positioning of the resources.
Do you acknowledge the problem ?
Have you done any modification for v7.3 ? Not seen any reference about this problem in the release notes.
