Graphics problems...
This topic has been viewed 57880 times and has 39 replies
Re: Graphics problems...
Found a solution:
1. uninstall sh3d
2. uninstall all old java jre
3. install new java jre 9.0.4 x64
4. download and use sh3d 6.3 jar file, not exe
1. uninstall sh3d
I tried to close almost every process in windows and found this to be responsible:
In my case the audio driver NahimicSvc32.exe has caused the graphical issue with the 32bit app.
Closing NahimicSvc64.exe helped also for the 64bit app version.
Patatusina
- Country: Italia
Thanks a lot, because I too by disabling NahimicSvc64.exe I solved it
Confirm the problem is there, but it is not necessary to disinstall or remove it, then disable the SOUND TRACKER
bouchetanne
- Country: France
Bonjour, j ai un problème similaire avec un pc tout neuf zenbook15 Asus, avec Ryzen7 et AMD RADEON. Sous windows11 64 bits. J ai installé la version sh3d 7.2 et la visualisation 3d plante complement, des traits partout qui ne ressemblent à rien. Surtout pour le mobilier. Help
Anne, mettez à jour le driver de votre carte graphique, c'est un problème déjà corrigé par AMD.
Enrico1972
- Country: Italia
Good evening, I'm using SH3D since years. Never had problems with previous revisions. Since I need the SW today, I bought last revision from Microsoft Store and it doesn't work properly. I have the same problem described by other users. My graphics drivers are already updated (NVIDIA RTX).
O.S. is Windows 11:
Edizione Windows 11 Pro
Versione 23H2
Data installazione: 21/09/2022
Build sistema operativo 22631.3447
Esperienza Windows Feature Experience Pack 1000.22688.1000.0
Hardware is:
Nome dispositivo Mostro
Processore 11th Gen Intel(R) Core(TM) i7-11700K @ 3.60GHz 3.60 GHz
RAM installata 32,0 GB (31,8 GB utilizzabile)
Tipo sistema Sistema operativo a 64 bit, processore basato su x64
Please let me know if you need further info.
PS Disabling "NahimicSvc64.exe" had no effect.
O.S. is Windows 11:
Versione 23H2
Hardware is:
- Daniels118
- Country: Italy
Can you describe the problem?
If you have the Pan 3D view plugin installed, maybe you should update it too to the last version; try to remove it first.
If anyone still has this problem:
https://www.sweethome3d.com/faq.jsp#err ... ringSystem
get the ini file from this post in FAQ and put it into the program's folder in program files (its all there in the FAQ).
This fixed it for me.
I had the same problem.
Disabling NahimicSvc64.exe solved it for me.
dell G15 5511, windows 11, geforce rtx 3060
